Replace valve springs on stock heads/cam?
Old Jun 11, 2005 | 02:32 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Hey folks -
I plan to have my valve seals changed and a set of comp 1.6 rr's put in this summer.
I don't plan on upgrading the stock heads/cam on my L98 in the future either, so I'm wondering if i should change the stock stamped valve springs to some new ones of the same factory size or not even bother at all.
Not too worried about valve float, but I figure since they are out why not.
Is there a brand/part # y'all can recommend if I should?
Old Jun 11, 2005 | 02:58 PM
91Z28-350's Avatar
Yes, change them. They are tired. Use whatever stock replacements fit in there (1.25" OD), but don't go overboard on seat pressure. CompCams, Crane, etc.
Old Jun 11, 2005 | 03:38 PM
Car: '89 GTA
The car has only 60K miles on it, but I guess they are 15+ years old as well.
I do recall reading the stockers are pretty weak.
Old Jun 21, 2005 | 08:26 PM
Car: '89 GTA
Can somebody tell me which of these two Comp springs would be the best to go with?
983-16 or 981-16?
The diameter, spring rate and valve spring style are slightly different on each.
Also, are retainers and locks a must as well?
10 degree? Part #'s?
Thanks!
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
NBrehm
Aug 25, 2015 11:49 PM
TheExaminer
Aug 25, 2015 07:34 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
