TBI to TPI help
Old Jun 13, 2005 | 06:46 AM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
TBI to TPI help
Finished doing the tbi/tpi swap and the engine wont start. I`ve checked the timing to make sure its not 180 off, checked that it was getting spark. How would I go about checking to see if the injectors are pulsing or what not? Also any other idea`s would be helpfull.
350 bored .020
zz4 heads
zz4 cam
25lb slp injectors
stock tpi setup
walbro 225 fuel pump
ajup chip
Old Jun 13, 2005 | 07:35 AM
dyeager353's Avatar
Car: many
Engine: many
Transmission: many
you can take a test light and see if it is lighting up. you can check my homepage under the thirdgen section or do a search on here.
Old Jun 13, 2005 | 09:20 AM
Car: `91 rs
Engine: 352 TPI
If the brake hose is not connected to the plenum, would that cause it to not start? Also, the map sensor vacumn line, does it need to be a certain size or does it matter?
Old Jun 13, 2005 | 11:13 PM
dyeager353's Avatar
Car: many
Engine: many
Transmission: many
there are many variables plug up the port on the manifold. And the hose size to the map doesn't matter.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
