Voltage problems, need help!!!
Old Jun 13, 2005 | 05:22 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I need some opinoins here guys, I am at a loss???
I installed a MSD 6A and a MSD coil, along with the MSD GM harness. I have had trouble ever since. First of all I can hear a loud clicking noise inside th ecar, I first mistook it for valvetrain noise. But I now realize it is comnig from the passenger side of the dashboard, which is where I have the MSD mounted in the engine bay. I am also experiencing a voltage drop, the voltage gauge drops down to the redline, as if the alternator has given out, and the stock tach is spiking up and down like crazy. And last but not least the car is idling very high.
Other than all that the car runs fine, pulls hard and has no issues. I shoud mention how I have it all installed I guess. The MSD 6A is on the firewall where the A/C box used to be. I have the postive run to the starting motor and the negative run to a location on the firewall where other grounds are run. It is a stock location on the passenger side of the distributor. The coil is mounted on the "new" heater box that I installed. But it is very close to the valve cover because of the length of the wires.
Should I run the MSD the way the instructions call for, the postive to the postive battery, and the ground to the negative battery? Should I mount the coil somewhere else because it may be getting to hot next to the valve cover? Should I put another ground on the MSD? Another ground on the alternator or the battery?
I am lost, please help!!!
Old Jun 13, 2005 | 09:12 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Your alternator is probably on its way out. The MSD box draws a solid ten amps and I have found that if the voltage on the car dips below 12.4 volts the MSD does not have enough power to fire the ign. properly.
I just traced my surging on idle to this problem and have ordered a new powermaster 140 amp alternator. My car was doing the same thing until after 5 hours of trouble shooting I figured out that the my old alternator could not keep up with the extra draw the MSD was creating on the electrial system for the car.
I will have my new alternator on Wednesday I will let you know how everything runs after the install.
Old Jun 13, 2005 | 11:17 PM
dyeager353's Avatar
Car: many
Engine: many
Transmission: many
many things can be wrong. Hardwire the ignition to a power source like a battery.
Old Jun 14, 2005 | 03:37 PM
speed88's Avatar
Engine: 383
Thanks for the suggestions, anyone else? Has this happened to anyone before??
Old Jun 15, 2005 | 11:43 PM
burnout88's Avatar
Car: 88 IROC
I put the new alternator on and it still does it. But the car definetly runs better with the new alternator. If I bpyass my MSD box the car runs fine. Now I am stumped.
Old Jun 16, 2005 | 06:39 AM
speed88's Avatar
Engine: 383
It sounds like you have a bad MSD box.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
