vss code 24
Old Jun 16, 2005 | 01:56 PM
rock'n z's Avatar
Car: 88 camaro iroc
Engine: 5.7 tuned port
Transmission: 700 r4
vss code 24
my speedomiter broke so i replaced it with an aftermarket mechanicle speedo now there was a photo cell in the back of the speedo that was my vss dose anyone know how to by pass the vss so my torque converter clutch can lock and my check engin light will stay off????? thanks for ur time
Old Jun 19, 2005 | 11:46 AM
Vader's Avatar
I am not aware of any easy way to eliminate teh VSS and still control the TCC. You can turn off the VSS error code in programming, but the ECM functions that rely on a VSS input will still have trouble. There are several, including VSS, fan opertion, knock sensor/EST operation, decel fuel cutoff, and a bunch that I can't remember.
Old Aug 27, 2007 | 12:14 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Re: vss code 24
With so many threads on VSS issues, I'll just add my problems here.
I did a '92 sd TPI swap into my '86 w/ t5. Left the cable drive to the speedo thinking that the VSS only affected the speedo. A few weeks ago I took it to the track (road course) and it ran like crap, no power, temps high (fans were on manual switch), floorboard hot. CEL came on and off a few times and would stall when I pulled back into my garage spot. Yesterday I drove it a bit til the light came on and pulled the codes. Code 24. duh. Search TGO find some answers. Current plan is to swap in the 'thingy' from the '92 parts car into the trans and plug in the connecter. I'll lose my speedo, no biggie.
From what I've found on TGO, this should correct the stalling. BUT people have said that other than that, it will still run fine, just not optimal (bad gas mileage etc).
Question is, is my problem elsewhere or do you think the vss is causing all my problems?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
