less restrictive Camaro Intake on Firebird?
Old Jun 22, 2005 | 07:28 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Is there a way to make a camaro intake fit on a firebird? I know that the camaro always had a little more HP b/c of it be less restrictive. Did anyone do this?
Old Jun 22, 2005 | 09:32 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I don't believe it will fit under the hood of a bird.
Old Jun 22, 2005 | 10:17 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Were you talking about the intake manifold or the cold air inlet system???? Because I thought the lower restriction was upstream of the throttle body, not downstream.
Old Jun 22, 2005 | 10:38 AM
Engine: 388 Carb
Axle/Gears: 4.10
I was talking about the cold air part.
Old Jun 22, 2005 | 11:20 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
the camaro intake is just as restrictive as the firebird..
there is also only 72ci of intake space.. not to mention the neck on the camaro intake is very restictive.. make your own charge air intake... i did, got all my 3" plumers tubing from home depot.. took me about 1 hour and 32$ for the tubing and 40$ for the 6" K&N cone filter.
Old Jun 22, 2005 | 01:51 PM
Engine: 388 Carb
Axle/Gears: 4.10
I have a maf so I would have to make one fit with that. I dont care about all the restricion really. As my car is still stock but for a few dollars I wouldnt mind.
Do you have any pics of yours?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
Jake_92RS
Aug 11, 2015 10:39 AM
