Need HELP with Injector Decision
Old Jun 22, 2005 | 07:55 PM
tommyboy51300's Avatar
I am debating to replace my injectors out of a 5.7 350 GTA without having to change anything else besides the injectors (i.e. AFPR, mod chip). I was looking at a set of HO 19# Ford Injectors Part # FOTE-9F593-DB5. Will these work in my setup? Are those injectors the same as these Part #397-M-9593-C302 from JEGS.com. Will these work in my car? Otherwise I was also considering a set of Accel 23# or 24# injectors. I need help and advice, Thanks in advance.
Old Jun 22, 2005 | 10:13 PM
357tpirocz's Avatar
I wouldnt take a brand new set of accel injectors for free. I have heard nothing but bad things about them. The stock 350 injectors are 22 lb so I definately wouldnt go with anything smaller than that.
Old Jun 23, 2005 | 12:31 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I would recommend the SVO's.
A stock 350 uses 22# hr injectors.
Best match from SVO would be the 24#'s and change the injector constant in your chip to 23.8 or have someone do it for you.
later
Jeremy
Old Jun 23, 2005 | 05:33 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I put a set of Accel 23# injectors in my 88 last year, working fine so far, no real changes needed. Might quit tomorrow?
Old Jun 23, 2005 | 06:56 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
I would go with the SVOs as well
Old Jun 23, 2005 | 07:59 PM
I was also leaning towards the SVO's but I thought that 19# SVO's run around 21 to 22 # due to fuel pressure. Am I wrong. I would like to get new injectors without having to change the constant.
Old Jun 23, 2005 | 11:59 PM
3.8TransAM's Avatar
A 24# SVO is just that in our cars, the 19's are 19's and the 30's are 30's.
They are rated for flow at the same pressure as GM is aka 43.5
Ford rates their injectors differently because they use 38 or 39 psi in their own vehicles.
A 24 is a 24 though I have even tested it out on a bone stock car. Ended up using 23.8 as the Inj. constant.
later
Jeremy
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
IROCZ1989
Sep 4, 2015 11:54 AM
