Gutting airbox and descreening MAF
Old Jun 24, 2005 | 03:31 PM
link85x's Avatar
Car: 1988 IROC-Z
Axle/Gears: 10-Bolt w/3.08's (dying)
How exactly do i go about this? Read it somewhere but i can't remember...
Old Jun 25, 2005 | 12:40 PM
Vader's Avatar
Before you do that, make sure you WANT to do that. If you had performed a search for the MAF screen idea, you would have already found your answer. You would likely have also found a good number of posts with the words "problem", "error code", and "descreened MAF" among the results.
For an otherwise stock LB9, there is little or no gain to be realized from removing MAF screens and heat sink fins, but lots of opportunity for problems. A 350 is a bit different story, but that is appearently not the case.
All that "free" horsepower you may believe you'll get may come at a significant price. Just perform a search of the board archives to arrive at a decision.
Old Jun 25, 2005 | 03:55 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I removed the screens and didn't notice a difference at the track.
Old Jun 25, 2005 | 05:50 PM
Vader's Avatar
With your cam profile, I'm just a little surprised you didn't get another tenth or so, but not completely surprised. To me, on a basically stock 305, the risk of problems is not worth the extra 2HP you might get from the alteration.
Old Jun 25, 2005 | 06:50 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
You might find this useful:
http://www.gmtips.com/3rd-degree/dox...low/warn-1.htm
Old Jun 25, 2005 | 06:54 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
And this:
http://www.gmtips.com/3rd-degree/dox...maf-screen.htm
I would take these articles into consideration until you get your engine built up some and these mods would make an actual difference.
Old Jun 25, 2005 | 10:18 PM
cdartz's Avatar
At the cost of $150 to replace the MAF removing the screens seems a bit retarded.
Old Jun 25, 2005 | 11:18 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
If it's the same MAF as an 86 I'll straight up trade mine. It came gutted and whether there are perfomance gains or not, I don't really like the idea of them not being there. I drive the pike through Boston atleast once a week.
Linson
Oct 24, 2025 02:00 PM
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
