tbi/tpi vats problem
Old Jun 25, 2005 | 09:32 AM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
Just did a tbi/tpi swap and the ecm is getting a code 46 for VATS. Supposedly, isn`t vats suppose to diable the fuel pump or does it disable theinjector drivers? I have my pump running and i have the signal going to the injectors but not the 12 volts.
Old Jun 26, 2005 | 11:53 AM
Vader's Avatar
AFAIK, if you have fuel pressure, and the ECM is pulsing the injectors,the VATS system is not the problem. The 12VDC source for the injectors is through the "INJ1" and "INJ2" fuses in the passenger compartment fuse panel. I don't believe that the VATS or starter enable relay interrupt this supply to the injectors. From my understanding, the VATS only inhibits the ECM from pulsing the injectors (on the switched ground side of the circuit).
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
