Code 22 what is wrong?
Old Jun 28, 2005 | 07:36 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I have replaced the TPS like a year ago. And now code 22 came on. I have checked all connections and they are fine. I have checked the calibration on the TPS and it is set properly. If i clear teh computers memory it takes about a week or two for the SES light to come back on. Any Ideas?
Old Jun 28, 2005 | 08:52 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
More than likely a bad ground that intermittently fails. Try to wire a meter to the battery - and to the sensor ground right at the sensor and then shake all the wiring to see if it ever breaks continuity.
Old Jun 28, 2005 | 09:33 PM
trueburton's Avatar
I'll give that a try I figured it was something in the wiring just wonderin if anyone else has had similar problems and how they fixed it. I have checked all the wires but i geuss i never did shake the wires will checking. Thanks, Kinda an obvious thing to do but some times it takes an extra mind.
BumpaD82
Feb 26, 2016 02:57 PM
Dyno Don
Jan 24, 2016 08:24 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
