TPS Problem ??
Old Jul 1, 2005 | 06:51 PM
Alan Billingham's Avatar
Car: Camaro IROC
Engine: 305ci
TPS Problem ??
After cleaning the throttle bodies and fitting a new TPS switch, still no voltage reading to set up the TPS ??
Car is running at 1400rpm at tick over, and engine fully warmed up.
No reading at all from the TPS, supposed to be 0.55 volts or there abouts. Car is putting out a code 22 only.
Alan
Old Jul 3, 2005 | 07:45 AM
Vader's Avatar
Verify that there is a 5.0VDC reference voltage between the 'A' and 'C' terminals of the TPS. Without that, there will be no signal to the ECM.
92camaroJoe
Jul 29, 2023 07:57 PM
GTAman
Sep 21, 2015 09:57 AM
soarestransam
Aug 24, 2015 08:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
