Anyone care to make a guess...
Old Jul 7, 2005 | 01:56 PM
Wind Charger's Avatar
Car: 1988 GTA TRANS AM, 1986 TRANS AM
Engine: L98, 5.7 TPI reborn, comp cam/heads maybe HSR this spring 5.0 TPI
...what HP and torque numbers an L98 would put out if it was bored out to a 355 with a stroker kit. As well as a Holley Stealth Ram, bigger cam better heads, underdrive pullyes, as well as my previous mods listed in my sig.
Old Jul 7, 2005 | 02:13 PM
Guest
Guest
Posts: n/a
355 stroker? Ok...
341.8hp, not one bit more.
Old Jul 7, 2005 | 02:52 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Originally posted by madmax
355 stroker? Ok...
You forgot to mention his torque....
375.674569 ft-lbs
Old Jul 7, 2005 | 03:02 PM
kevinc's Avatar
Car: 1982 Z28
Re: Anyone care to make a guess...
Depends on what you're doing to the stroke to get 355ci out of a 350ci stock engine...tell us more.
Old Jul 7, 2005 | 08:54 PM
well it turns out that the ol L98 may not be as bad off as I was lead to believe. My mechanic said something like the engine might have swallowed a vavle so he was going to pull off some rockers and check it out. If it is only that, Im not going to pull the engine and rebuild it in the near future. Im just going to Stealth Ram it and cam it, new heads, underdrive pulleys and 3.73 gears, in addition to the previous mods. If the engine needs to be rebuilt Im going to talk to the guys at the rebuild shop on Tuesday and discuss the rebuild with them. Im not looking for anything too special. Just a solid 300 HP to the wheels without N02 or forced air induction. Anything over 300 is gravy.
Old Jul 8, 2005 | 07:56 AM
kevinc's Avatar
Car: 1982 Z28
If it dropped a valve, you'll be tearing down the engine. Depending on how fast the engine was revving, you may be shopping for a whole new shortblock.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Victor6
Aug 30, 2015 02:09 AM
mizz0313
Aug 12, 2015 06:45 AM
Fronzizzle
Aug 9, 2015 01:15 PM
