Adjustable FPR performance ?
Old Jul 9, 2005 | 05:51 PM
fixin87formula's Avatar
Car: 1987 Formula T-top
Transmission: 5-speed
I have read on here that the Adj. FRP only adds power at WOT. True or False?
Old Jul 9, 2005 | 09:18 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Well it should alow for better tuning allowing for more power at every rpm, especially at WOT.
Old Jul 10, 2005 | 03:12 AM
83 Crossfire TA's Avatar
The ECM will compensate for a 15-20% change at part throttle, but it will effect full throttle… on my stock 87 L98 I ran my fastest quarter miles with between 52 and 54psi base pressure, but that was also enough that I was getting some black soot on my back bumper during normal driving
Old Jul 10, 2005 | 01:16 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Are they helpful even on a relatively stock car? At this point in the game, trying to conserve MPG in a V8 is like making orange juice w/o destroying the orange.
Old Jul 10, 2005 | 02:37 PM
Reread my original post… yes, it was a stock L98, and although the higher fuel pressure did leave soot on the back bumper, I wan’t able to log any change in mileage.
V8’s can be built to have good gas mileage, but a TPI or 350 are not the ways to go there…
Old Jul 10, 2005 | 07:40 PM
Car: 1994 Trans Am
When you say best times, how much better than the stock pressure? I guess give me some numbers. After headers, I will doing the little things while I save up for my paint job. Like, port TPI, afpr, airfoil, tb bypass....yadda yadda yadda.
Old Jul 10, 2005 | 07:47 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
In *most* cases, an AFPR will not do much good for a stock car. But it depends on the specific application. A good tune will do far more. My car (302, granted) was substantially modified, but it still ran best with stock or very very close to stock fuel pressure, even though I did have an AFPR. What it DID need was a tune, but never got it before the motor blew.
Old Jul 11, 2005 | 01:33 AM
As per the corrected numbers in my timeslips spreadsheet, looks like it was around .09s and 1.3mph in the ¼ at 52psi vs stock
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
92-Formula
Dec 12, 2015 10:34 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
