Slp Cai
Old Jul 9, 2005 | 11:31 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
Slp Cai
Got a Q about this kit for the 88 formula
installed it perfectly
but i used the elbows they sent in the kit
i noticed inside the elbows there were like metal baffles/deflectors
the original ones on her car did not have those metal baffles inside her tubes
does it matter?
seems like to helps to make it sturdier
and i was thinking it would help the air flow with them being inside there
thoughts?
Old Jul 10, 2005 | 11:55 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The baffles are supposed to help the airflow. It is an improvement over the factory system. I had one on my car for a number of years.
After examining the SLP product I decided I could build a better one with more flow and a bigger air filter than the stock one.
Old Jul 10, 2005 | 11:57 AM
Car: 1989 GTA
Engine: 369 TPI
Wrong picture above. See attached
Old Jul 10, 2005 | 01:14 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
2 questions 1989, what did you do about the return hose from the resevoir? With my cai, the weight has ripped the hose, so I was thinking of some metal or hard plastic elbow piece in place of the rubber hose, and then have the rubber hose go under the intake?
And did you custom make those runners? They look like WAAAAAy overkill on my 305, but they look sweet.
Old Jul 10, 2005 | 03:09 PM
Car: 1989 GTA
Engine: 369 TPI
Hi
Look carefully in the picture and you can see that I relocated the overflow hose on the radiator around the corner to the passenger side. Those runners are highly modified SLP runners. See attached picture.
Old Jul 10, 2005 | 07:46 PM
Car: 1994 Trans Am
I don't have my car in front of me right now, but is there another nipple on that side of the radiator? Did you plug the "stock" nipple or something? Is that even a stock radiator? Sorry for the questions.
And for those SLP runners, for some reason they look different from any others I've seen. Really cool!
Old Jul 11, 2005 | 01:19 PM
Car: 1989 GTA
Engine: 369 TPI
Yes I plugged the stock radiator overflow and moved it around to the passenger side so that my 3.50" cold air intake would work. Yes that is the stock factory radiator. Those SLP runners have been heavily modified. It shows what can be done with them. Allen
Old Jul 11, 2005 | 05:15 PM
Car: 1994 Trans Am
Here's my idea, I can cut off the hose nipple, JB weld the hole shut. Drill a hole in the other side and JB weld on a new hose nipple? Isn't there pressure on the walls of ther radiator or is JB weld strong enough? Obviously you got it to work, I'm just wondering how to get there. Thanks.
Old Jul 11, 2005 | 05:36 PM
Car: 1989 GTA
Engine: 369 TPI
Here is what I did. I cut off the factory nipple down to the square part and tapped the hole. Don't remember the exact size. Then I installed an Allen head set screw with sealant.
On the new side I also drilled and tapped the whole. Trying to remember the size but I think a 1/4 inch hose nipple with 1/4 inch male pipe threads or something along that line. Also used sealant. Could even have been 1/8 inch. Just don't remember.
The pressure is not nearly as great as in the radiator. It has been working fine with absolutely no problems. Allen
Edit: Where the word "I" is present substitute "Dyno Don". He did the work and I just supervised and rounded up the parts.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
