Injectors Chevy/ford
Old Jul 12, 2005 | 08:16 AM
3leggedog's Avatar
From: It's a west coast thing, you may not understand?
Car: 88 IROC, tpi, t top,
Engine: LB9
Transmission: 5 speed
I was told ,by a very good mecanic, that injectors are the same for chevy and ford. I was at a junk yard and sure enough a ford v6 injector plugged right in to a v8 tpi? Now I Know flow rate has to be right for the engine. But they looked the same. Same thing from a jeep. So are all 19lbs injectors the same???????
Old Jul 12, 2005 | 10:50 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
If they're rated to flow at a certain velocity, then they probably do -- the only thing I could think of that might be different is the duty cycle, but I don't know where you'd obtain that information.
Most fuel injectors use standardized connectors and universal fittings. Thirdgens use Bosch-style plugs, which is the same as many Fords, Jeeps, etc. I've heard of people swapping Ford SVO injectors into their Thirdgens, but I'm not sure of their flow rate.
Old Jul 12, 2005 | 09:59 PM
3leggedog's Avatar
Engine: LB9
Yea that sounds so unlike the big 3 (chevy,ford, dodge ) !!!!! I was told to buy ford 19lb because there cheeper. I have no deep seated need to use a ford part!!! But I am still amazed they are the same part. Thanks for confirming my junk yard test!
Old Jul 13, 2005 | 10:30 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, they are not the same part, but they are interchangable.
Chevy injectors for the 305 TPI are rated at 19#/hr, while the 350 TPI injectors are rated at 22#/hr. Fuel pressure at 43.5psi.
The LT1 cars got an injector rated at 24#/hr.
Fords injectors are rated at 19#/hr or 24#/hr for most of their 305s or 350s. This flow rate is measured at 39.5psi fuel pressure.
FWIW: I am running Ford's 24#/hr injectors in my 395 stroker at 52psi. This is with the stock TPI fuel rail.
Old Jul 14, 2005 | 07:36 PM
3leggedog's Avatar
Engine: LB9
I have also been told to use the stock O rings instead of the ford ones. Mostly for ease of fit? Dose this sound right also? So I may also need to retrim my fuel presure as needed.
Old Jul 14, 2005 | 08:49 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I don't think it would matter that much, unless the non-GM injectors had an outside diameter that was different than the GM fuel rail (unlikely IMO, since the injectors are of a standard form factor).
Don't forget to lubricate the O-rings before you install them. I like to use a light application of white lithium grease.
Old Jul 14, 2005 | 11:03 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i have ford motorsports 19lb injectors with ford o-rings and I'm still on my stock fuel pressure regulator and I have no problems what so ever
Old Jul 16, 2005 | 07:22 AM
LittleNo's Avatar
Car: 91 TPI Caprice
Transmission: TH700R4
just BTW: the reason, why so many fuel injectors of different manufacturers are the same style is, that the multipoint fuel injection systems were developed by Bosch in the late 70ies
When i did troubleshooting on my TPI Caprice (with 89 350 TPI setup) i used injectors from a VW VR6 engine for testing.
Old Jul 16, 2005 | 08:35 AM
3leggedog's Avatar
Engine: LB9
Thanks bosch!! https://www.thirdgen.org/techbb2/new...readid=309110#
Old Jul 16, 2005 | 04:36 PM
TexasB4C's Avatar
Car: 92 Camaro B4C 350
actually the duty cycle and pulse width are controlled by the PCM
Old Jul 16, 2005 | 06:21 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Good point about the duty cycle... I've been reading so much on fuel tuning in the ECM that I've forgotten the most basic of things .
Old Jul 16, 2005 | 06:37 PM
TexasB4C's Avatar
Im going to UTI/ Hot Rod U so im learning ALOT there about everythng....
i start the actual hot rod courses next week we get to play with and learn about nitrous, superchargers, turbos, all the fun stuff finally
Old Jul 16, 2005 | 09:55 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
You have to know three thing if its a bosch style injector, Lbs. per hour, psi measured @ and high or low impedence.
Since when does ford make 305's and 350's
Cough 302, cough 351
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
