New TPS not in spec and fully adjusted in one direction
Old Jul 18, 2005 | 10:53 AM
cdartz's Avatar
As stated in the topic I installed a new TPS. I'm reading 0.52 volts closed and 4.35 at WOT. I believe the closed reading should be 0.54 but I can't get it there as I'm already adjusted completely in the one direction. There is no more adjustment left. Does this sound normal to you guys? Shouldn't I be more to the middle of the adjustment instead of at the extreme end to get these numbers. I'm thinking I should get another TPS.
Old Jul 18, 2005 | 11:03 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That's ok....anywhere between .52 & .63 is good.
Old Jul 18, 2005 | 11:16 AM
Wayne's 383Iroc's Avatar
Car: 88 IROC
Engine: 383
I set my closed at .6 to .62, the WOT should be more than that reading 4.8 to 4.9 with a 5v signal.
Old Jul 18, 2005 | 05:52 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Carefully bend the little tab/sweeper back some..may have been abused in shipping.
Old Jul 18, 2005 | 06:21 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Chris installed a new TPS and got the same readings as you this past sat.
Old Jul 19, 2005 | 12:32 AM
cdartz's Avatar
I may end up grabbing another one from work and trying it. I bought the last one though so I'll have to wait till our shipment comes on Thursday. For now it's running ok.
Old Jul 19, 2005 | 07:21 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I'm not worrying about it sine it's w/in the +-.07 range
Old Jul 19, 2005 | 10:31 PM
cdartz's Avatar
I'm not worried about the range. It's basically within spec. It's the fact that it's adjusted completely in the one direction that bothers me. There is no more room to adjust if it would become necessary later on.
I think I'm gonna check my minimum air screw and see where the throttle plates are sitting when closed. Changing that may in turn allow me to more adjustment with the TPS.
Old Jul 20, 2005 | 04:40 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I tried that but can't keep it idleing low enough.
customblackbird
Aug 15, 2021 10:16 PM
BAMiller
Sep 14, 2015 06:38 PM
db057
Sep 4, 2015 07:57 AM
BurlyChev
Aug 22, 2015 11:42 AM
