manifold bolt question
Old Jul 22, 2005 | 03:21 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
will there be any clearance issues with regular(12 point) bolts, cause I would love to ditch the torqx
Old Jul 24, 2005 | 10:55 AM
Vader's Avatar
"Regular" 12-point heads? Those are actually fairly rare. If you can get 12-point headed bolts, they shoudl have no clearance problems since they are typically smaller than their 6-point counterparts. A regular 6-point (hex head) cap screw may present soem clearance issues, however.
Another alternative to the Torx button heads would be hex recess cap screws (Allen heads).
Old Jul 24, 2005 | 08:36 PM
kairles's Avatar
Engine: 383/LGX
wow I didn't know 12 point bolts are rare, Im gonna order some stainless 12 point bolts from jegs
Old Jul 25, 2005 | 10:44 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
don't you mean a flat socket cap head screw?
Old Jul 31, 2005 | 12:04 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
ACTUALLY IT IS SOCKET HEAD CAP SCREW
Old Jul 31, 2005 | 10:34 AM
Vader's Avatar
The original fasteners were Torx recess, button head cap screws. Flat cap screws are just that - Flat on the outer head surface with a 37° tapered underside.
12-points are available at any good hardware store, and many other sources. I mentioned they are "fairly rare" since they usually cannot be found at the stores that are displacing the local hardware stores across the country. The big box home centers aren't going to be able to help you, or possibly even understand what you might be asking for, whereas the old hardware store clerk would have asked "Plain, or plated, and how many?"
12-points should work just fine, so long as you can find them with the correct thread and length.
Old Jul 31, 2005 | 08:11 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Watch the length, a couple will hit a push rod if too long. And a sealing washer isn't a bad idea either.
Old Jul 31, 2005 | 08:56 PM
kairles's Avatar
Engine: 383/LGX
I plan to order some S.S. ARP's from JEGS. Is the TPI any different from a SBC
I plan to get these: part # 070-434-2101
http://www.jegs.com/cgi-bin/ncommerc...12&prmenbr=361
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
