l98 engine specs help piston cc, ect
Old Jul 28, 2005 | 01:38 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
89 l98 with g92 , what is the piston dish cc and the piston to deck clearance im trying to calculate my compression ratio i am putting a set of trick flow heads 23degree with 64cc , my head gasket thickness is gonna be .041in and upto 4.166 bore.
stock bottom end, i would like about a 9:5:1 to 10:1 compression ratio,
Old Jul 28, 2005 | 10:13 PM
87IROC350's Avatar
Engine: 5.7
If I remember correctly the l98 heads are 64cc rated at a ~9.25:1 compression stock. I think .40 is usually standard head gasket size so unless you go with a thinner gasket you really haven't changed anything an you'll end up with ~9.25:1 compression ratio.
Old Jul 30, 2005 | 09:22 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Mine had flattop pistons, 64cc heads, 1.94 intakes. Pistons were down around .027 inch. Factory stock engine in the 89. To do it right you might want thinner gaskets if they can be used with these heads.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
