Dyno Results....
Old Jul 30, 2005 | 05:26 PM
vwdave's Avatar
Dyno Results....
232hp/311lb-ft.
LT4 Cam, 981 Springs, Comp Cams 1.6RR's, 1 5/8" Shorties, ported upper plenum.
Temperature was 100*F and damn near 100% humidity.
Thoughts?
Old Jul 30, 2005 | 05:33 PM
xtransxamx's Avatar
i love you dave
Old Jul 30, 2005 | 05:41 PM
vwdave's Avatar
Aww Freaky Petey love you too Hahaha....you know how I do.
Seriously, back on topic.
Old Jul 30, 2005 | 08:29 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Nice numbers bro! Any idea what it made before the Cam?
Old Jul 30, 2005 | 08:31 PM
vwdave's Avatar
Nope, put the cam in with the engine.
Old Jul 30, 2005 | 10:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
For your mods I think those are good numbers. Normally the dyno will convert to SAE numbers for consistancy. You are making at the rear wheels about what the car made at the crank when stock.
Old Jul 31, 2005 | 02:20 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Someones gonna yell cause I'm going to say it.
Work on the tune if u havent.
MAF tolerates mods better than SD but doenst get u the best from it.
I put down 225 and 315 at the wheels on a stock91 GTA, only "mods" were a catback and 24# inj and my own prom tuning.
Car was smoking hot on the run too, as in 220 deg since the dyno ate the results for the first run and wouldnt record torque
later
Jeremy
Old Jul 31, 2005 | 05:58 AM
vwdave's Avatar
I havent worked on the tune at all. I am going to goto a Holley 950 Commander so it'll be easier to work with.
The dyno showed my A/F staying at 11.7-12.0 the entire way. Flat as a board.
Old Jul 31, 2005 | 06:36 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
A/F should be around 13.0 It may of been flat but the wrong ratio.
Old Jul 31, 2005 | 06:30 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Is that the non-HOT standard LT4 cam? I'm curious why you choose that if so, even with the 1.6s that is a very mild cam not much bigger than the standard 350 TPI cam would have been with 1.6s...
Old Jul 31, 2005 | 06:32 PM
vwdave's Avatar
Didnt know any better at the time. It is slightly bigger though.
Old Jul 31, 2005 | 06:43 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Oh, the numbers I have for it peg it at 203/210 duration w/ .476/.479 lift (with 1.6s)
vs the 207/213 dur .415/.430 (be around .445/.460 w/ 1.6s) for the standard 89 350 TPI cam.
So just slightly more lift, negligibly smaller duration, I would be curious to see how the 350 TPI cam would have dynoed in comparison. On the bright side it leaves you plenty of room to improve later if you decide to ever step up the intake, etc...
Old Jul 31, 2005 | 06:45 PM
vwdave's Avatar
I want to go with a Holley 950 Commander, HSR, XE276HR. Which heads are where I am stuck. Probably would be better to run the Trick Flow 23's. Mostly for budget reasons.
Old Jul 31, 2005 | 08:28 PM
Car: 1989 GTA
Engine: 369 TPI
The Trickflows will do you well. Make sure you get the right version to match your lift. They sell them with three different spring rates. I got the double springs myself.
Old Aug 1, 2005 | 12:09 AM
3.8TransAM's Avatar
Stick with the 165 or upgrade to the 730 and spend your money on other things for more worthwhile than the Commander setup
later
Jeremy
Old Aug 23, 2005 | 10:03 PM
vwdave's Avatar
later
Jeremy
You know, I got into the hold DIY Prom stuff, bought the $500 equipment so I can do it myself from Craig. But at every turn, I am having some sort of a weird problem that doesnt let me actually tune the car. I finally got it to read and made all the adjustments and I went to "Burn" the e-prom and it wouldnt let me. At this point, I was so angry I let the car sit for 6 months and lost all interest in it. The programmer sits in my toolbox at work. I cannot even stand to even look at it.
The way I see it, I have 3 options.
1. Sell Prom burning equipment, Put a 950 Commander in it.
2. Pay someone to do chips for me and just send them the logs.
3. Sell Prom burning equipment and put a carb on it. This is a last resort.
I am sick of the tuning issues I am having with it and dammit, I am going to get them fixed come hell or high water.
Old Aug 23, 2005 | 10:29 PM
Guest
Guest
Posts: n/a
What are you running right now, chip wise? I'm not seeing that but assume its a MAF setup?
Old Aug 24, 2005 | 12:59 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Where did the peaks occur (my guess - 4400/3150) - and can you post a graph?
Old Aug 24, 2005 | 05:23 AM
vwdave's Avatar
Stock.
Torque - 3800
Horsepower - 4600.
Old Aug 24, 2005 | 09:57 AM
GOY's Avatar
GOY
Wow I was way off on the torque peak. I also vote on ditching the Commander setup idea. Take a walk to the DIY Prom section... OEM ECM's are capable of running just about any setup.
Old Aug 24, 2005 | 10:07 AM
Guest
Guest
Posts: n/a
6e? 32?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
