oil in runners!
Old Jul 30, 2005 | 10:00 PM
dbdragger's Avatar
oil in runners!
Has anyone else had pooling of oil in the runners. I pulled the plenum and runners on THurs and found about a tablespoon of oil in the runner of 6 cyl. and lots of misting oil in the plenum.
Any opinions.
Old Jul 30, 2005 | 10:45 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
How many miles on the motor and how old is the PCV valve?
Old Jul 30, 2005 | 10:51 PM
dbdragger's Avatar
It's a new block, 12000 km on it and and it has the new PCV valve since the new motor.
Old Jul 30, 2005 | 10:57 PM
Rob Wade's Avatar
Either there is to much crankcase pressure (bad PCV) or you have a ring sealing problem. Stock valve covers. You need to have baffle if they are aftermarket valvecovers. You may be sucking oil out of the valve covers if there isn't any baffles.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Leaking intake gasket around that cylinder.
Old Jul 31, 2005 | 07:26 AM
Rob Wade's Avatar
Car should run like sh-t though. How did it run? Bad Idle?
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
CatmanFS
Sep 19, 2015 09:00 AM
toronto formula
Sep 10, 2015 07:31 AM
