Can a severly cracked Y-Pipe be my problem?
Old Jul 31, 2005 | 06:27 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Hey guys I got a 86 305 TPI camaro, with 93k on it. The Y pipe is severly cracked, with a crack running completely from one end of the exhaust manifold, to the other manifold. I got 4 codes in my computer, a 32, 34, 43, and 44. I replaced the O2 sensor around when I first got the car 3 months ago. Lately the car has really been acting up though. Runs sluggish sometimes, hard to restart after warmed up, or has a hesitation on throttle response. So with these codes being a lean code, a ESC code, a egr code, and a MAF code, Im thinking it may be possible they are all routing from the same source? Any Ideas?
Old Jul 31, 2005 | 06:33 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I'm not an expert, but I would say with a crack that big you could have some problems. I would think that most of your exhaust is coming out there and not through the muffler. Can you smell the exhaust fumes inside the car? I would get that fixed and clear the codes and see how it runs.
Old Jul 31, 2005 | 07:26 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Is it actually leaking bad? Some of these forward pipes are double wall. Symptoms sort of lead me to a fuel pump or filter instead. Try a new filter first. I'd sure replace that pipe as soon as possible though.
Old Jul 31, 2005 | 08:07 PM
Already replaced the fuel filter with a new ac delco one. did fuel pressure tests on it when i first got it, and it stayed right in spec. Also did a cleaning of the injectors with injector cleaner from a dealership. Yes, I can also smell the fumes inside the car. Thanks for these reply's guys, keep em coming! I dont want to start throwing alot of money I dont have into the car right now.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
hectre13
Sep 8, 2015 03:38 PM
Bryan F
Aug 18, 2015 02:28 PM
