Cam selection
Old Aug 2, 2005 | 03:16 PM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
Cam selection
ok guys i got a question im going to be getting a cam for my 305 tpi i dont want anything radical, but i want the most performance i can get without sacrificing too much gas milage and without having to do other mods to make the cam work. so what size would you prefer?
edit: also what do you think it would drop my 14.93 s @ 91.3 to?
Old Aug 2, 2005 | 03:36 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Cam selection
Your silly..
-- Joe
Old Aug 2, 2005 | 04:35 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Installing a cam with more lift and duration will result in reduced gas mileage. The other consideration is a rough idle. This is the trade off. You just can not get the most performance without affecting gas mileage. It all depends on what you want and what you are willing to sacrifice. Take a look at these camshafts by Comp Cams 08-407-8, 08-408-8, 08-412-8, 08-500-8, 08-501-8 or 08-502-8. They can be found at the following site:
http://www.compcams.com/Technical/Cu...ML/128-169.asp
When I asked my mechanic to install a cam in my new 305 the first thing he asked me was if I wanted a rough idle. I did not and I also did not want it to affect gas mileage too much. I was willing to get some more power without a large loss in fuel economy. He phoned Comp Cams and they recommended the 08-412-8 camshaft for what I wanted. I have been pleased with this choice for what I wanted at the time.
You can install a camshaft with out any other modification. However, headers, a more free flowing exhaust, better heads, porting the intake system, better fuel injectors, an adjustable fuel pressure regulator, etc. will all work to permit you to get more out of your camshaft. But you will want to consider these modification when deciding on a camshaft. You will not get the most out a very large camshaft without at least a few of these other modifications.
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
