help with next upgrade?
Old Aug 6, 2005 | 06:24 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
my car has the following, engine wise:
block - cast, 355ci, cast pistons and rods, hydraulic flat tappet cam, duration at .050 is 204in, 214ex. valve lift is 422in, 444ex with 107in, 117ex lobes
heads - cast, 305 58cc, 1.84in valves, freshly machined
intake - bone stock TPI
fuel - venom pump, LS1 25# injectors with custom clips
exhaust - Full edelbrock exhaust, including headers and 3" cat back with catco cat
thats pretty much it for the engine, i'm also running an OEM air filter... never really figured an air hog would really make a noticeable difference, also i heard it could cause check engine lights b/c of the oil and whatever.
Please let me know what other mods i should do that keep the budget under 2,000. thanks guys!
Old Aug 6, 2005 | 06:56 PM
bigchief's Avatar
lol i find it hard to believe that no one has any idea's
Old Aug 10, 2005 | 12:26 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
siamese/port the intaek- it's free- and is def. needed
Old Aug 10, 2005 | 12:34 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Gears and tires.
Old Aug 10, 2005 | 12:41 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Accel Base, Ported SLP Runners, Gears.
Old Aug 10, 2005 | 12:42 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
sub frame connectors, larger base and runners, port plenum, afpr, chip burner
Old Aug 10, 2005 | 05:12 PM
bigchief's Avatar
awsome guys, thanks a lot, i think im actually gonna save up for the TPIS system runners and base, that seems to be an awsome setup.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
