Need some advice
Old Aug 9, 2005 | 08:56 AM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
Need some advice
im gonna be gettin a 87 formula pretty soon. has the 350tpi motor. car has been sittin for 3 years not running. i was wondering wha ti would need besides a fresh battery to get this thing started? im gonna try to get it running be4 i buy it so i can move it and look underneath for any rust. so im gonna be doing this at a guys house
Old Aug 9, 2005 | 09:25 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Gas. The stuff that is in there is so old, if it will even run the engine, it will run badly. IF you can, drain the tank. If there is not much in there, just add about 5 gallons of 94 octane, and see if it will start.
May want to look for critter nests under the hood before you start though..... Sucking a mouse thru the intake tract would be bad..... (and I don't think the mouse would appreciate it either...)
Old Aug 13, 2005 | 11:22 AM
Vader's Avatar
Good advice, but I'd suggest using the LOWEST octane fuel possible for the "recovery project". Lower octane fuel has a higher volatility, and slightly higher solvent properties. Since the existing fuel that remains has probably lost some of its volatility, the fresh fill of low octane should tend to dilute some of the remnant and clean/clear it out a little better.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
