Need ideas on cam for 305
Old Aug 11, 2005 | 07:28 AM
jonarotz's Avatar
Car: 91 Z28
I am currently running a 91 305 with an LT1 cam. Over the winter I am going to go through and port out the 081 heads and the intake. I also want to add a better cam. I am spraying it with 150 shot and I have a best time of 13.10@101mph. My 60' foots are good with a best of 1.75. It launches hard but lacks the potential in the big end of the track.
I have bigger injectors, a 2200 stall converter (actually flashes around 2500), 3.73 gears and a built up 700R4.
What cam would you guys suggest?
Old Aug 11, 2005 | 10:52 AM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
http://www.compcams.com/Technical/Se...umber=08-304-8
Old Aug 11, 2005 | 12:00 PM
chikn305's Avatar
Take a look at the lpe 211. I have that cam in my car and it seems to be running good. My setup is: ported sr 305 heads, lpe211 cam, 1.6 rr, big mouth base, edelbrock runners, ported plenum, edelbrock headers, 19lb injectors, stock throttle body, 2800 stall, 3.73 , and highly untuned. Last week the car went 8.01 1/8 mile w/ a 1.66 60ft with a 100 shot. I'm going back tomorrow with a 150 shot and scan tool so I can start tuning.
Old Aug 11, 2005 | 12:46 PM
jonarotz's Avatar
Car: 91 Z28
Does anyone have any experience with the ZZ4 cam? The only reason I ask is because they can be had for much less than the two previously mentioned cams.
I was actually looking at the comp cam, but I wanted to gather some more input.
Thanks guys.
Old Aug 11, 2005 | 05:35 PM
chikn305's Avatar
there was a guy on here a few years back that ran the zz4 in a 305 and his car ran mid 13's n/a with the usual bolt ons
Old Aug 11, 2005 | 06:26 PM
Z69's Avatar
Z69
You'll get more HP out of heads than you will a cam.
Jake_92RS
Jan 28, 2020 10:37 PM
pimp2303
Jul 27, 2017 02:03 PM
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
