black smoke on startup
Old Aug 13, 2005 | 03:06 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
Hi guys,
I have a 91 305 TPI that runs rough and belches black smoke when first started in the morning. It only happens when the car sits overnight, restarts during the day are fine. The car will run rough until everything clears out and then runs ok. Could the injectors be dripping fuel when the car is shutoff? Any way to test them, I didnt know if a simple ohm test would be relevant in this case. If I were to put a fuel pressure guage on the car what should I see as far as pressure and how long should it hold before I can assume the injectors are leaking by? Thanks for any help!
Old Aug 13, 2005 | 03:17 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Im not up on the TPI injection system but I think some have a cold start injector. What it actually does im not sure but it sounds self-explanitory. Black smoke means its rich.
Old Aug 13, 2005 | 03:25 PM
drptop70ss's Avatar
Car: way too many
Thanks but the 9th injector wasnt around for 91. Anyone else?
Old Aug 13, 2005 | 06:52 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Injector(s) stuck open.
Old Aug 13, 2005 | 07:24 PM
drptop70ss's Avatar
Car: way too many
any way to verify it with the fuel pressure guage?
Old Aug 14, 2005 | 10:33 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
The pressure will drop to zero when the pump stops.
gta892000
Aug 11, 2019 11:16 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
m00n420
Sep 11, 2015 02:39 PM
IROCtometal
Sep 9, 2015 10:01 AM
Accerrito22
Sep 5, 2015 09:34 PM
