Mod Maf?
Old Aug 16, 2005 | 02:13 AM
I-Roc with my Z's Avatar
Car: 1989 Iroc_Z
Mod Maf?
Should I mod the maf...I did once...but when I brought it to shop for new gas tank they felt the need to put a new one for some odd reason in because they said the sensor got too dirty for the burn on relay to work. Has anyone else modded their maf and had idling problems or anything? Any not mod their maf for a specific reason-Modding as in removing screens and definnig it.
Old Aug 18, 2005 | 01:20 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
http://www.gmtips.com/3rd-degree/dox...maf-screen.htm
Old Aug 20, 2005 | 08:35 AM
Vader's Avatar
Mike's article appears to be mostly correct. It is important to understand what Mike has described about the various functions of the screens. Least important is the "filter" idea. Most important is the need to create controlled turbulence in the intake air flow to get an accurate measurement in the sampling tube of the MAF.
If you really want to spend all your time at WOT and feel the need to eliminate the MAF screens, you're wasting your time. You really need to convert to speed/density and tune via programming. If you want any kind of emission control and fuel mileage (and engine life), be very careful about how you alter the MAF.
Old Aug 22, 2005 | 07:32 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I wouldnt do it IMO
Old Aug 24, 2005 | 08:30 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
i did it, no problems with at idle or WOT or anywhere inbetween. BUT I also didnt notice ANY differnce in doing it.
Old Aug 24, 2005 | 09:24 PM
QuickStyle's Avatar
Car: 91 Z28
nobody should notice a difference because the cfm for the maf sensor already outflows the whole intake system. its like putting a 3" catback exhaust on your car with a 2" cat, its only gonna flow just as much as the 2" cat can. and why risk something that does nothing for a $300 dollar sensor, the screens are there to protect the wire inside it, and by removing the screens, you put the wire in danger.
Old Aug 24, 2005 | 09:47 PM
boost creep's Avatar
Look at this....
http://www.efitune.com/forum/index.p...=ST&f=2&t=349&
Old Aug 24, 2005 | 11:22 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Originally posted by boost creep
Look at this....
Yep, just saw that today when a friend was doing some tuning on my car. I removed the screens on the MAF 5 years ago when it seemed like the thing to do. Now I know I shouldn't have. At least it's fixed now in the code, and runs much better.
Old Aug 25, 2005 | 05:46 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You know putting a 3" catback on a 2" cat equipped car will still show an improvement. The restrictions are cumulative. Yes, there is a bottleneck, but the smaler the bottle neck the better. And I agree, removing the screens is pointless and risky.
Mark_ZZ3
May 24, 2018 01:02 PM
racereese
Oct 3, 2015 03:46 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
