Importance of clips?
Old Aug 16, 2005 | 05:50 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
How important are the injector clips? From a search I found people run without clips on some aftermarket injectors.
I ask because when I recently replaced all of my injectors with stock units I could not get the clip to engage the fuel rail on one injector, no matter what I did. Can I leave it alone, or must that clip engage the fuel rail? I'm really not looking forward to an engine fire.
Old Aug 17, 2005 | 02:10 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
you dont need them. just make sure you stick the injectors in the rail first and then the entire rail with the injectors attached into the manifold.
Old Aug 17, 2005 | 03:27 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks Smurfn', that's how I put it together.
Old Aug 17, 2005 | 05:02 PM
Guest
Guest
Posts: n/a
https://www.thirdgen.org/techbb2/sho...injector+clips
Old Aug 18, 2005 | 03:41 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks Max. Its injector on cyl #4 I can't get the clip on.
Any sugestions on getting the clip into place with the fuel rail installed? I just can't get the stupid clip to rotate... it's hitting the piece of metal that forms the groove and preventing it from going into the groove. I held the injector with two fingers andpulled the clip tight to the rail which worked for some of the others, but no matter what I do I just can't seem to get this one to clip.
Old Aug 18, 2005 | 04:00 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Ive replaced injectors 3 times, dont have any clips onthem now. No problems so far.
Old Aug 18, 2005 | 09:54 PM
Guest
Guest
Posts: n/a
Try squeezing the clip, when you take them off and put them back on, sometimes the outer diameter increases past the size of the groove in the rail. I think thats the problem youre having.
RS Reaper
Oct 17, 2018 07:52 PM
Night rider327
Feb 25, 2016 09:50 AM
92-Formula
Dec 12, 2015 10:34 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
James Sutton
Sep 23, 2015 01:56 PM
