ISC idle set not working
Old Aug 23, 2005 | 08:48 PM
phishfud's Avatar
Car: 88 GTA
I have been fighting a cold start/stumble issue, and had reset my timing yesterday, which improved it. I went to do the ISC reset today, and followed the procedure, but even when I back the torx screw all the way out, the car still idles at 1000 in drive, fully warmed up, with the ISC unplugged. The instructions say to set it to 400 in drive. I cannot figure why the idle will not go down. After everything is plugged back in, I am throwing NO codes, and the car will idle normal ( 800 or so in Park, 550-600 in drive). Any idea what is happening? Could I have put the U shaped paper clip in the wrong pins on the ALDL? Should I try retarding the timing while doing this to get my 400, then when all is done with the ISC reset the timing again? Any help would be great. Thanks.
Terry
Old Aug 24, 2005 | 05:32 AM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
I was having difficulties when going by the instructions on the tech page too. I searched these forums and found a picture of a service manual that helped. It's the last post in this thread.
Hope this helps.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
hectre13
Aug 26, 2015 08:17 AM
zeitghaist
Aug 18, 2015 07:33 AM
