MAF to MAP
Old Aug 28, 2005 | 08:05 PM
cyrius's Avatar
Car: crossbreed
Engine: 350 4 bolt
Transmission: TH350
Axle/Gears: 4.56
MAF to MAP
engine specs.
-305 (hot cam, headers, roller rockers etc.)
-'86 TPI, ecm 1227165, no harness (missing MAF sensor also)
-TH350 tranny
the tpi is off an '86 F-body 305
i'm switching over to the MAP system as the engine is a ways from stock and the vehicle is nowhere near stock
whats a good, easily findable ecm to look for? (i'll need to reburn it to match my engine/vehicle)
Old Aug 28, 2005 | 08:45 PM
Section162's Avatar
Car: '90 Formula
Engine: L98 --> Ramjet
The 1227730 is the MAP TPI ecm used in thirdgens ('90-'92). It was also used in lots of other cars (even six cyls, I think). The '727 is a weather-resistant underhood version of the '730 (used in the vettes). You might want to check this out:
http://www.cruzers.com/~ludis/p4xref.html#1227730
If you haven't already, I'd look at the stickies in the DIY-PROM board. Also, I believe there's an article on how to convert from MAF to MAP on the main page, that might help you a bit.
HTH.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
