That ignition timing wire
Old Aug 29, 2005 | 12:35 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Ok there are two wires and I cant figure out which is the ignition timing wire...1 is near the blower motor, and ac unit. Its a small wire thats tan. Then there a small wire back by the distributor, near the brake booster. 1 wire on this connection leads to my distributor
Old Aug 29, 2005 | 01:06 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the small tan wire by the blower motor is the wire you disconnect to set initial timing. if you did not disconnect this wire while setting the base timing, then your timing will be wrong.
Old Aug 29, 2005 | 09:08 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Absolutely correct. Here's pic showing it courtesy of Vader, I believe.
Old Aug 29, 2005 | 09:45 AM
Car: 1991 Z28
Engine: SBC
ok thanks guys i apprecaite it
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
