Plenum Porting
Old Aug 30, 2005 | 02:03 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Plenum Porting
Removing the restictive inner walls in the upper plenum will give you how much of a performance gain? Is it noticeable and worth the trouble? How did it feel up top after?
Old Aug 30, 2005 | 10:15 PM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
On my 305, I didn't notice too much in the lower rpm's but the motor pulled a lot harder in the upper rpm range. I also did some porting around the runner holes. There's a "wall" between the sets of holes that you can remove some material from.
Old Sep 1, 2005 | 12:15 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
My setup is in my sig . With the whole aftermarkeet TPI base and runners ported AND the plenum . I think you need it all done at once to notice it . I don't see a huge gain from it unless you incorporate other intake mods to exaggerate it's benifet. This is mine
With the runners ported and this done . It just made the power curve fall of more gradually past the 4800 rpm mark. I still ended up looseing only 15 hp from 4800 to 5400. So I say it does help...a bit
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
