Well its that time to replace my fuel injectors. I need peoples opinion on who has the best injectors at a fairly good price and what lbs injectors should i get. and whos has crappy fuel injectors i should stay away from. this is a 350 tpi
The best buy and most respected brand are the Ford Racing SVO injectors available from Summit or Jegs for about $220/8.
Most, but not all, say to avoid the Accel injectors. About $260/8.
You can also get good take-out (used very little) LS1 injectors from SLP (SLPonline.com) for about $100/8.
Stock 350 injectors are 22# so I'd stay pretty close to 22# or 24#.
That's the info I've come up recently when I did the search for my injector purchase.
vernw
close
- Join DateJul 2003
- LocationDallas, TX area
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car91 Formula WS6 (Black, T-Tops)
- Engine383 MiniRam (529 HP, 519 TQ - DD2K)
- TransmissionBuilt '97 T56, Pro 5.0, CF-DF
- Axle/Gears4.11 posi Ford 9"
- Liked:0 Times in 0 Posts
And remember the LS1 28# injectors are really 24# at our fuel pressure. (said from a dude selling 2 sets that aren't big enough for my 383)
for a good, cheep setup I'd go with a set of LS1 injectors and an AFPR.
sound good guys
i would just watch out with those ls1 injectors b/c your gonna need custom clips with them, i had to make custom clips out of regular c-clips, i cut them to fit on the injector and hold it in place. do not run these injectors without clips! ask someone on the forums what you should do about the clips first.
