tpi wiring question
Old Sep 1, 2005 | 03:52 AM
Faceman's Avatar
Car: `89 Firebird Formula LS1
Engine: LS1 HA HA HA
Transmission: 4L60
tpi wiring question
Hello
I`m trying to make a conversion from TBI to speed density TPI. I have all the parts except from wiring. I cannot obtain one even from ebay where people can pay over 200$ for used wiring that`s insane! My friend has a MAF wiring , my question is: is it possible to convert the MAF wiring to MAP wiring? Or will I have to buy MAP? If it is possible I`ll buy the MAF wiring from my friend and convert it to MAP and finally make a TPI conversion.
Please help!!
Old Sep 1, 2005 | 07:07 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I converted MAF to MAP and I didn't have to run an extra wires.
Old Sep 1, 2005 | 07:22 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
There should be a post or two if you search under the phrase "Repin." In fact, you can repin you MAP TBI to MAP TPI if you don't mind a little sodering, and running a few extra leads.
Old Sep 1, 2005 | 07:26 AM
GOY's Avatar
GOY
Here it is
https://www.thirdgen.org/techbb2/sho...ight=repinning
Caspar
Jun 19, 2016 11:19 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
