chip question
Old Sep 2, 2005 | 09:16 PM
grndprixss's Avatar
Car: 85 pontiac grand prix
Engine: 355 tpi
chip question
i was at the corvettes at carlilse show this past weekend and i was talking to a programer who was doing wonderful things with the ls1 platform i was asking him about the tpi and programing, he says he uses a stock chip even on a good modified motor (heads, cam etc) and he plays witht eh iac, tps and the base timeing, to make the car run with serious improvments, does this sound right to anyone?
Old Sep 3, 2005 | 03:09 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Sounds like a load of crap to me.
I can fudge with my TPS and my IAC and timing and that doesnt do squat if I stuffed in a cam and my lower VE was rich as all get out :-)
I would serioulsy suggest ignoring anything someone of that nature has to say and find a competent tuner
Or better yet head over the the DIY PROM board and check out the beginners stickies we have set up at the top of the forum
later
Jeremy
Old Sep 3, 2005 | 05:48 PM
Vader's Avatar
What he said. I'm relatively certain he knows, too.
It may run acceptably once or twice, but certainly won't be consistent, if only the base timing is adjusted. If you've found an "expert" that has devised a method to "adjust an IAC" I'd like an opportunity to speak with him/her. I've yet to fathom how anyone can "adjust" a dual-coil DC stepper motor outside of controlling the ECM directly.
Obviously, this person was intentionally misleading you, or didn't have a friggin' clue about that of which he spoke.
I'll give $100 to the first person that can demonstrate how to effectively "adjust" an IAC motor without proramming. Cheating the ECM by adjusting the throttle minimum air position stop screw doesn't count, since that does NOT constitute "adjusting the IAC". It's on the table, ready for mailing. Ramming the pintle in for installation doesn't count either.
Old Sep 3, 2005 | 08:53 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
Maybe he meant IAT instead. I could see that.
I agree that he doesn't sound very competant at this point.
Old Sep 5, 2005 | 10:04 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
LOL
Originally posted by Vader
I'll give $100 to the first person that can demonstrate how to effectively "adjust" an IAC motor without proramming...
Proramming, I'm always willing to learn something new.
Old Sep 5, 2005 | 10:24 AM
Vader's Avatar
Hang around 3.8Trans and the rest of the regulars on the DIY PROM board. You can learn a few things about programming.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
