Fixing runner dents witha ball bearing trick?
Old Sep 5, 2005 | 09:12 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
I've heard of a ball bearing trick to get rid of dents in runner. You're supposed to force the ball through and the dents pop out. What do you use to push it throguh? I want to try this for my exhaust headers but dont know of anything to push it with.
Old Sep 7, 2005 | 08:10 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Dead blow hammer, or i suppose?
Old Sep 8, 2005 | 02:13 AM
IROC-Turbo's Avatar
More Bearings behind it??Then use hammer of choice??I need to do that myself for the set of headers i use to ground start engines and annoy the nieghbers .
Old Sep 8, 2005 | 01:03 PM
Mark 89Formula's Avatar
How about attaching a cable to the ball bearing long enough to extend all the way through the runner or header tube and pull the ball through?
Old Sep 8, 2005 | 01:16 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You're going to have to pull rather hard. More bearings is the more common and logical way.
Old Sep 8, 2005 | 01:36 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
Bearings are damn expensive, anyone know of a cheap site?
Old Sep 8, 2005 | 03:19 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i found this
https://www.thirdgen.org/techbb2/sho...t=runner+dents
Old Sep 8, 2005 | 04:44 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Call up AS&M or SLP and send you a new set
Old Sep 8, 2005 | 06:59 PM
colonboy14's Avatar
Car: Trans Am
I know somebody makes a "tool" which is a set of steel ***** that get progressively bigger. You start with the smallest one that wont fit through, and just force them through with a hammer until you get to the biggest one which is the diameter of the runner. Might want to search for that, sorry I can't remember where I saw it.
Old Sep 16, 2005 | 03:14 PM
91 z28 350's Avatar
Car: 91 Z28
Ebay has the ball bearings for $45
Old Sep 17, 2005 | 05:19 AM
S10Wildside's Avatar
They're the wrong size! I ordered a set from that guy on ebay and they're too small. Any large dents will look better after running the ***** through, but the dents are still very obvious. If you really want runners that look like new, forget about the ***** on ebay (and the lousy "shim" he includes). The shim is simply a piece of packaging banding that will split before running the ***** through every runner.
37mm is the largest ball that will pass through...and will not make the runners perfect. 38mm is barely too large to pass through.
I don't understand why everyone keeps saying that the professionals use steel *****. If they do, then that's only part of the process. I had Street and Performance remove dents from my runners and the markings inside the runners, where the dents were, had indication of a side to side rocking motion. They must be using a smaller ball on a hardened rod to massage the dents out. They also blast the runners with steel shot to produce a finish that resembles the Corvette runners. This abrasive finish looks good and covers up any scratches and very, very small dings.
Old Sep 17, 2005 | 09:27 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
take them too a shop that polishes horns and other band instruments. they can remove the dents. they have all sorts off tools for just this type of thing. special spoons, ***** ect. it takes some sweet talking but, they can do it
Old Sep 18, 2005 | 05:04 AM
I've been meaning to do that. I used to play trumpet for a guy who owns the local Brass and Woodwind repair shop. Got a few sets of runners that need a little work.
Old Sep 18, 2005 | 08:16 PM
net_coma's Avatar
I think I would be looking around for replacement runners...and driving a bearing through a set of dented headers...no thanks...I would rather replace or live with it than endure the nightmare I envision.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
