Holley stealthram install
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi guys!
I am about to install a new holley stealthram and wounder what more than the intake and fuelrail do i need to get.Different injectors maybe?
Car: 1988 GTA TRANS AM, 1986 TRANS AM
Engine: L98, 5.7 TPI reborn, comp cam/heads maybe HSR this spring 5.0 TPI
dude theres a whole board about this under the alternative EFI intakes forum.
Just thouht Id let you know before someone yells at you for not using
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Injectors really depend on what else you've done to the car. You will need...
Intake Gaskets -Felpro 1205
AN Braided Line -6
AN fittings
To either grind/bend your old throttle body so it wont hit the new fuel rails or buy a holley/bbk etc.
To read about the swap here...
Stealth Ram
AN Braided Line -6
AN fittings
Stealth Ram
86IROC112
Aug 17, 2015 02:00 PM
gaskets, gta, holley, instalation, install, installation, intake, l98, ram, stealth, stealthram, tpi, trans
