help with injector size for setup.
Old Sep 7, 2005 | 09:44 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
im going to be running the following. please suggest what minimum injector size i should be running. thank you so much!
355 TPI with TPIS base and runners.
Full edelbrock exhaust including headers and 3" cat back with cat.
58cc 305 heads with 1.84 valves.
let me know if you guys need more info! thanks again
Old Sep 7, 2005 | 11:52 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
You'll be fine with either a 22 lb or 24 lb injector. If you go with 24, you need to make the proper change in the prom.
Old Sep 8, 2005 | 01:27 PM
bigchief's Avatar
oh ok cool. would it have to be bigger if i went with different heads? like a 350 head with 2.02 valves instead of 1.84's? if so how big? i'd preferably be using something close to an edelbrock performer set of heads.
Old Sep 8, 2005 | 03:42 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
So long as you are running a naturally aspirated TPI intake, you won't need anything larger than 24. That would be good to about 400 hp. There is a formula thats been posted before where you calculate the needed injector size for a given application. You should be able to find it easily with a search.
Old Sep 8, 2005 | 03:50 PM
bigchief's Avatar
awsome man, that sounds great. thanks a lot for the help!
Old Sep 8, 2005 | 09:35 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
definately go to the 24lb inj. stock l98s should have had them from the factory.
Old Sep 8, 2005 | 10:06 PM
bigchief's Avatar
im actually using the LS1 injectors at the moment and i just wanted to know if they would be ok for further upgrades to my TPI. they shoot at i think 28lbs for the LS1 fuel pressure, and the TPI fuel pressure is 24lbs i think.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
