86 TPI T/A problems still
Old Sep 10, 2005 | 01:16 PM
vette&T/A's Avatar
Car: 86 Trans Am
I finally got the Trans back, I took it on a couple errands today and the car ran great until it died when I was idling along, I was able the start it up right away and it was fine like nothing happened, and it did that once more before I got home. The check engine light is not on anymore, when the service light comes on when it dies will that be stored to pull a code? And also the shop got it to run good, but the dealer told them that they wanted to replace all 8 injectors which would be $1200, I know that I can get them cheaper but that's how much I paid for the car frickin A. So any help would be appreciated, thanks. Brandon
Old Sep 10, 2005 | 03:40 PM
Vader's Avatar
The injectors used in '86 were Rochester / Bosch. They are probablyt worth servicing. Fire up your email and start chatting at www.cruzinperformance.com
Old Sep 11, 2005 | 09:06 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
Just a thought. I also had a problem with the car dying when going very slow. I was having a new fuel pump put on anyway, but after I picked it up, it died 2 blocks from the garage. So I started looking around, I pulled the rubber boot off the front of the throttle body, and flipped the blades. Total grime. I then noticed some black in front of the blades, at the hole at the bottom. So I sprayed it all out with carb cleaner and it has worked fine ever since. I am thinking that is part of the idle circut, and it was gummed up. It is worth a try, it only costs a few cents.
Old Sep 11, 2005 | 09:15 PM
vette&T/A's Avatar
Car: 86 Trans Am
yeah i'll check that and it seems real random, starts back up real nice though, would there be a code to read if service engine light came on when it died
Old Sep 11, 2005 | 09:42 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
I am pretty sure I did not have any codes showing.
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
