88 350 tpi need HELP!!!
Old Sep 16, 2005 | 10:04 PM
rocz's Avatar
Car: 88 IROC-Z 91 RS
Engine: 358 in the roc 305 in the rs
Transmission: 700's
i got my car back on the road a cople of months ago nev motor ect the problem is it stats verry hard sometimes and blows a puf of black smoke out the pips. then other times it fires right up, i meen like the starter hits the flywheel and it is running. also every once and awile when i shut it off then jump back in in it sets the SES light and goes into limp mode, it i turn it of wate like 2 min it is fine. And last of all this gust started today when we were messing with it under hard accelration it stats surging???
anyone got any ideas what going on
thanks
Old Sep 17, 2005 | 04:44 PM
rocz's Avatar
Transmission: 700's
ok had it on the scanner today and the coolent temp was reading 249 put a new one on it read 247 when i un plug it it reads 113 wtf help anyone
Old Sep 17, 2005 | 05:22 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
these are you reading after it has fully cooled down right? over night should be the same or very close to the same IAT sensor reading KOEO
if so and you unplugged the coolant temp sensor like you said. it sounds like the wire has grounded out somewhere (possiably on your exhaust?)
Old Sep 18, 2005 | 07:21 PM
rocz's Avatar
Transmission: 700's
it reads the same hot or cold. i dont think it has grouned out on the exhaust b/c it is up in front of the intake and all the wires are between the runnere and valve covers
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
