Engine Knock
Old Sep 18, 2005 | 03:02 PM
Lime's Avatar
Car: GS
Engine Knock
I was looking at an 88 Iroc, and the guy says it has knock and claims that a new crankshaft will fix it. or a new engine (well no **** eh?). its a 350tpi. How much damage could I cause if I drive it home? (about 40 miles). How much are the odds that only a new crank will fix it? Or would a new lower end be in order?
Old Sep 18, 2005 | 08:13 PM
net_coma's Avatar
New crank+bearings for rods and mains is a new bottom end. If you take the time to do that then do the rest as well. Engine with a bottom end knock is probably indicitave of other problems and wear. Negoiate the price based on the need for major engine work....remember it all has to come out to replace a crankshaft. Don't buy it for a penny more than your price...not his or you will need KY along with the shaft.
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
