Looking for pic of Knock Sensor
Old Sep 22, 2005 | 12:29 AM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
I was looking around some threads for a code 43 and everyone is saying that the knock sensor seems to be the problem. Does anyone have a pic of the knock sensor laying around? I just replaced the starter and i think i know which one it is but i couldnt figure out how disconnect the damn thing. Im sure since i pulled the starter out i bumped it so i want to pull the connector and check the voltage and such if not just replace the sensor. Thanks
Old Sep 22, 2005 | 07:17 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Passenger side block beneath the exhaust manifolds. Shouldn't be hard to find. I can't recall what color the single wire is going to it.
Old Sep 22, 2005 | 08:14 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
squeeze the connector to get it off, it's the one directly in front of the starter, only sensor in the block on that side, the other (fan temp switch) is in the head, and it has the same type of connector on it.
EDIT:
Typo; should read, "only sensors in the block on that side.
The reason I mentioned the temp sensor is because it uses the same typ of connector and can be confused with the knock sensor, some have even unknownly swapped the connectors.
Old Sep 22, 2005 | 09:29 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Hmmm..I thought the sensor on the right side between cyl's 6 & 8 was a coolant temp sensor. What is the sensor on the left side of the block between cyls 1 & 3?
Also, I may have a 305 sensor on the left side as described above (run a 355), is that harming anything?
Old Sep 22, 2005 | 11:24 AM
BOSS 357's Avatar
Engine: 357 SBC TPI
http://chevythunder.com/fuel%20injec....%20pg%20B.htm
Try this link, there a good pic here. With the sensor pictured here, I know this particular one is located on the left side of the block, right under/between cylinders 1 & 3.
Good Luck.
Eric
Old Sep 22, 2005 | 03:43 PM
Car: 86 T/A
Engine: HSR 355
1&3 is coolant temp sensor for the gauge I believe. 6&8 is knock sensor.
Old Sep 22, 2005 | 06:23 PM
Guest
Guest
Posts: n/a
Knock sensor is on the bottom of the block at the oil pan rail.
The sensor between the 6 & 8 cylinders is for the cooling fan.
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
