maf sensor?
Car: 1985 camaro z28
Engine: 305 tpi
maf sensor?
ok when i first got my car about 6 months ago the check engine light would come on (code 33, maf sensor) if i shut it off and restarted it the light would go away and the car would run fine, today i go to start it and the light came on for the first time in about a 3 months, try to restart it about 10 times and it would still run like crap,i go knock on the maf with the car running, it still ran the same, unplugged it and it still ran the same, does this sound like the maf is shot or a wiring problem?
thanks in advance
thanks in advance
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
It could potentially be a MAF Power or Burnoff relay, fairly common problem on these cars. They are a 10 dollar part and are interchangeable. Happend to mine, 20 dollars later and the car runs like a champ.
Engine: 305 tpi
i dont think my **** bastard car has them relays, it has a burnoff module that cost around $300, i think 85 was the only year to have it
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
$300? Maybe in 1986. Last time I checked it was around $800 or $900.
Your best bet is to buy a used module. This is assuming you can narrow your problem down to the module.
Engine: 305 tpi
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Eithers either the module or the MAF, either way its gonna get expensive. See if you can borrow one somehow to avoid fixing things that aren't broken.
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Might almost be cheaper to upgrade to an 86 setup eh?
Its fairly easy to do, I didn't even try and start mine on the 85 setup.
Here is some good info on the swap
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
`165 ECMs are dirt cheap, and pretty common, the new MAF would be the most expensive part of the upgrade.
Former Sponsor
Car: 1992 Camaro RS
i can get one from advance auto for $275
Engine: 305 tpi
went out the other day and wiggled the connection at the maf for about the 100th time, started it and all was fine. took it for a spin shut it off then went to restart it, and the same problem. wiggled the connection again and all was fine..... i think this car needs a exorcism
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
