HSR Gaskets, where did you get your replacements?
Old Sep 22, 2005 | 02:42 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I took the HSR off yesterday to re-do the intake gaskets and fix the oil leak on the rear china wall and took the plenum off as well. The plenum gaskets were destroyed when the plenum was removed and the parts stores don't carry them.
I used this FelPro Engine Seal gasket material and had to cut out a pair of gaskets, which was a major PITA.
Old Sep 22, 2005 | 04:10 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Weiand Hi-Ram Replacement Intake Manifold Gaskets
Got mine through summit, bought a few sets for later use, summit part # WND-8984.
Old Sep 23, 2005 | 10:35 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Formula350sd found they can also be had as Holley #108-119
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
qz6lwp
Aug 20, 2015 08:10 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
