tpi will not idle all od the sudden
Old Sep 27, 2005 | 07:28 AM
easyrider394's Avatar
Car: 86 Iroc
I have a 86 Iroc 305 TPI....this morning I started my car, it started fine idled for about 30 seconds then I realized I forgot got something in my house so I shut off the car...because my house key is on the same keychain...when I was done getting what I needed, I tried to start my car again...and not it just cranked and cranked...soI waited a minute or so and tried starting it again...it did the same until I touched the gas and it started right up...so I reved it up a bit and as so as I let off the gas i stalled with no struggle..like I turned the key off...so I started it again, and the same thing...i dont have any Idea what it could be ...does anyone else...any help would be greatly appreciated.
thanks
Old Sep 27, 2005 | 09:40 AM
LittleNo's Avatar
Car: 91 TPI Caprice
Transmission: TH700R4
sounds like a bad IAC
Old Sep 27, 2005 | 10:04 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Any codes? If no codes, unplug the maf and see if it'll start and run without the gas pedal depressed (albeit not well). If so, likely a MAF relay went.
Old Sep 27, 2005 | 06:22 PM
78camaroz28's Avatar
Car: 2001 Trans Am WS6
The irony will kill you....
How about that...same exact thing happened to me this morning in my 86 T/A. I got in the car, started it right up and it promptly died (of course I was already late for work) like a big vacuum leak. It ran fine last night... When I got home this evening and started fooling around with it, I heard the IAC making a clicking noise. No codes (except the ever present code 32....). Since its acting like vacuum, and the IAC is making all that racket, I suspect it has to be that.
What a PITA...
Old Sep 27, 2005 | 08:35 PM
...and the IAC it was!
Took another off a spare t/b I had and swapped it. Runs like a champ again.
Now off to the races...also known as daily driving here in San Antonio...
Old Sep 27, 2005 | 08:49 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
exactly what my car did about three months ago. Fired it up to move it across the lot so it wouldnt be in the way and when I went to leave about half an hour later it woulndt idle on its own, turned out to be a bad IAC.
Wade787b
Sep 29, 2015 01:15 PM
mdtoren
Aug 23, 2015 12:52 PM
zeitghaist
Aug 18, 2015 07:33 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
