maf relay/sensor
Old Sep 30, 2005 | 06:14 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
maf relay/sensor
guys my car is acting wieerd 87 350 firbird
well anyhow
i start it itll go up and then stall, once its kinda semi idling good if i tap the gas it almost stalls depending on how much gas i give it
if i put it to the floor itll hit about 190 rpm :/
itll catch up but its scary itll make a pop noise in the intake then zooooommm to the rpm the gas was sposed to be, i just replaced the relays for the maf if i unplug it the throttle responds nicely....the idle is just rough
any advice guys
thanks !
Old Sep 30, 2005 | 06:18 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
A maf problem will trigger a code and a check engine light. Any vacuum leaks? Have you worked on the motor lately? Timing ok? Check the basics first, especially if you don't have a light on.
Old Sep 30, 2005 | 06:20 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
ses is on for sure
only when i have the maf plugged in * thinking to myself wtf!? * lol
yes i think i do have a vacuum leak from one of the tb hoses but nothing major
timing- no clue lol
hmm what else
Old Sep 30, 2005 | 06:21 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
i have worked on it i cleaned my tb and threw a new gaskets on it* tightened it evenly to specs
Old Sep 30, 2005 | 08:52 PM
Rob Wade's Avatar
If you have a vacuum leak that is most likely your problem. Your getting "unmonitored" air throwing the idle off. What code is it?
Old Sep 30, 2005 | 09:58 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
ive gotten code 21 before, i havent checked in a week :/, will do tomrow hehe paper clip style
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
