TPI stock gas odometer bouncing
Old Oct 3, 2005 | 04:27 PM
shad's Avatar
Car: 1988 Iroc
Engine: 350 TPI 5.7L
Transmission: 700r-4
my 350 tpi 5.7L engine on my 88 iroc runs amazingly, it only has 30k orig miles on it. However, when my gas tank is about half way, the lil meter bounces back and forth, but i dont know what causes this? There is vacuum in my gas tank, but i think thats standard for a tpi. It is hard to guess how much gas i have left in my tank and i dont want to push it, only because the meter jumps around.
any suggestions? open for advice. THANKS!!
-pete
Old Oct 3, 2005 | 06:48 PM
sting's Avatar
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
Does it also take longer to come off of full? Both of mine do that, the last half seems to go faster then the first half, when braking hard or turning hard corners the meter jumps around, then climbs slowly. Climbs back to where it should be when she starts moving. Is that what you're talking about? or is it something more serious?
Old Oct 3, 2005 | 08:01 PM
shad's Avatar
Car: 1988 Iroc
yea something like what you posted, and downhill it goes up, uphill it goes down im guessing that the gas measurement is in the rear of the gas tank. but **** its soo hard to tell how much gas u have sometimes
Old Oct 4, 2005 | 06:10 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Mine does this as well, and it is my understanding this is normal as the tank tapers near the bottom, however the sending unit is still somewhat linear. Since the taper makes the tank larger at the top, the tank will seem to empty slower when full than when half full or less.
As for the bouncing, sorry, I can't help you there...
Old Oct 4, 2005 | 07:06 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Sender has a worn spot(s) where it isn't getting a reading.
If you keep a new vechicle full all the time, it will eventually start reading just before full no matter how much you top it off, this is another reason for it to take longer to come down.
It's just the nature of the beast.
Old Oct 4, 2005 | 06:20 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Our tanks have a floating gauge, they're supposed to move like that.
Old Oct 4, 2005 | 06:44 PM
z28 NyC's Avatar
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
Yeh that same problem was bothering me a while ago, Goumba's right though it sucks but its just somthing u gotta live with man.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Sep 1, 2015 03:51 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
kyle5647
Aug 7, 2015 03:08 PM
