tpi on 86 t/a if you step on the gas car sputters
Car: 1990 rs camaro v8 5spd & 86 t/a 5.7 tpi
Engine: 305 rs-- 350 t/a
Transmission: 700r4 t/a not sure rs
i have a 86 t/a 5.0 tpi when i step on the throttle hard the car sputters the wont return to normal unless i shut the car off now it does the same thing on its own please help
Car: '86 T/A T-tops
Engine: '86 305 TPI (stock)
i had the same problem for a while but mine was throwing up a knock sensor code... after i replaced the knock sensor i started to fill it up with premium gas... no problem since... you can try a little octane boost by the directions on the bottle... but you should do a tune up first. mine had a recent tune up when it happened. if that doesn't get the problem straight, then let it warm up to normal temp first then try to run it.
Iroc8t8
May 4, 2026 08:09 PM
AkDrifted
Aug 17, 2015 07:45 PM
