Want to upgrade my cap and coil...what to get?
Old Oct 4, 2005 | 09:34 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm currently running MSD igntion...and now I would like to upgrade my cap and coil...especially since the cap and coil are original. I've seen some MSD products in JEGS and would like to order from them...but I'm unsure what to get. I was recommened to get the MSD "Blaster" coil..but there are several different types. Any help is appreciated. Thanks
Old Oct 4, 2005 | 09:38 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
AC Delco is what I run.
Old Oct 5, 2005 | 01:11 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I have the blaster 2 coil for my car.
Old Oct 5, 2005 | 01:56 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
nothing i have used is better than the stock GM coil.. ive used MSD (failed in 3 months) and Accel (failed in 1 month)
1992 stock GM coil.. still going strong..
and im not the only one who has had MSD problems.. tons of guys have had problems with their coils.. and crappy 6AL boxes.. that damn box was the root of my non existing power above 3500rpms..
for a cap.. eh.. Delco.. or Conrad
Old Oct 5, 2005 | 07:21 AM
ncgator's Avatar
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
ive got the blaster and haven't had any problems yet
as for the cap i just got the 'upgraded' blue one from advance auto
Old Oct 5, 2005 | 02:10 PM
Engine: 5.7
it looks like there are several types of "blaster" coils. Which one do I get?
Old Oct 5, 2005 | 02:27 PM
ncgator's Avatar
Car: '89 Trans Am
MSD-8226 (SummitRacing.com) is what i have
Old Oct 5, 2005 | 02:43 PM
Engine: 5.7
thanks for the part number man, I won't need a wiring harness or anything will I?
Old Oct 5, 2005 | 02:59 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I believe that is the same one that I have. MSD offers a direct replacement coil that will connect to the factory wiring..
Old Oct 5, 2005 | 03:02 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I have the same coil.......it will plug right in , same as the stock one. But i bought a harness when i used my MSD 6A box with it. You can wire it up yourself,but i didn't want to mess with it.
Old Oct 5, 2005 | 03:08 PM
Engine: 5.7
Ok, I know what you mean....I also bought the harness when I installed my MSD box, just wanting to make sure before I place an order. Now, how about that dist. cap?
Old Oct 5, 2005 | 03:11 PM
Car: 92'Camaro RS
Engine: a loud one
Then you should be good to go as soon as you get it. One tip though...I thought the mounting bracket they give you is rather cheap. So i drilled out the rivets on the old coil and reused the stock brackets.
Old Oct 5, 2005 | 06:42 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I run a GP Sorrenson factory replacement, works fine.
Old Oct 6, 2005 | 06:36 AM
ncgator's Avatar
Car: '89 Trans Am
i did the same
Old Oct 18, 2005 | 01:56 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I reused the factory bracket (same as others), drilling out the rivets and grinding a little to clear my Edelbrock TPI base. I use the specific MSD coil for this application (MSD-8226), although I have to admit this is my second MSD coil. I did have the first one fail rather soon, kinda disappointing. For the second replacement MSD coil, I painted the exposed coil core surfaces (bare metal) with electrical varnish (glyptal), to keep the surface rust down and seal the internals against moisture, etc, hopefully make the coil last longer. I used a separate ground strap to provide a good grounding connection from the coil to the firewall surface grounding point. Sofar, so good.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Fronzizzle
Feb 9, 2017 09:31 AM
84 TA NV
Sep 6, 2015 08:02 PM
TBRays98
Sep 6, 2015 05:05 PM
