Need picture of hoses
Old Oct 6, 2005 | 10:22 AM
Ackattack's Avatar
Car: 99 Corvette/72 GMC
Engine: LS1/L98
Transmission: M6/700R4
Axle/Gears: 3.42/3.73
I have a L98 in my pickup, and the hoses running to and from the waterpump, throttlebody, and intake are kinda messed up. Anyone have pictures of they way they're supposed to be routed. Right now I'm just using generic hoses, are there oem ones that are formed to fit better so they don't kink.
Old Oct 6, 2005 | 04:40 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
yes there are formed hoses, but many people don't hooke up the coolant lines to the throttle body
Assuming you are not using the heater core by pass valve, you really only need a generic heater hose with a formed right angle. Run that from the pipe at the front of the intake manifold to the heater core pipe on the firewall.
Old Oct 6, 2005 | 08:25 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Headers and No A/C really clears up the engine bay. Accually looks feasible to change the plugs now.
Old Oct 7, 2005 | 06:47 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
I really need to get rid of more clutter, just haven't had time.. that's an old pic though, before I switched to speed density.
The lack of A.I.R. helps a lot, but the headers make changing plugs a pain in the *** still. With the stock manifolds and no AC and the AIR removed on my old IROC I was able to do all plugs from up top in about 15 minutes time.
Old Oct 7, 2005 | 08:49 AM
Ackattack's Avatar
Engine: LS1/L98
where do you get the hose with a 90 degree bend in it?
I'm working on cleaning up the engine bay. I managed to run the spark plug wires under the headers....gives it a real custom look, but makes some things a pain (like setting the timing, cause I have to use the wire near the distributor, rather down by the spark plug, so I have to figure out which wire it is (doesn't take much, but you konw)
Old Oct 7, 2005 | 10:35 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
any decent parts store should carry it. I use a local chain, that has people that actually know about cars lol. It costs a little more sometimes, but it beats going to Pepboys or Autozone and trying to get anything that the kids can't easily look up on the computer.
Those two stores also *should* carry it.. just generic heater hose with a formed 90 degree on one end.. mine was like 3 feet long, just cut to fit your truck.
Old Oct 12, 2005 | 02:43 PM
87MCLS's Avatar
Car: 87MCLS
Transmission: 350 TURBO
Jay this message is for u. I am going to put TPI in my car. I need to know how to route the vacuum line. I saw a pic that showed the front view. Is there anyway that you could take somemore pics that would show better detail of were everything goes. Do u know if I can use an electric fuel pump(40 pounds or more) instead of putting one in the tank? I have a mass air setup.
Hotrodboba400
Dec 10, 2019 07:07 PM
tonys91rs
Oct 10, 2015 03:31 PM
Linson
Sep 21, 2015 01:08 PM
Strick1
Sep 6, 2015 02:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
