Code 42...sort of
Old Oct 8, 2005 | 04:22 PM
MiikeS's Avatar
Code 42...sort of
I've converted my '72 Blazer to TPI and all seems to be going well except for 1 minor problem....well maybe 2.
First, The SES light is dimly it at all times. I've gone over all the wiring and it seems to be correct. Any hints?
Second, I get a code 42 when hooked up to a scanner but not when I jumper the ALDL. Wierd. I've gone through the whole diagnostic thing for a code42 and came up with bad ECM. So, I picked up another off Ebay and it didn't fix things. I'm stumped. Are the 2 problems related?
It's a MAF setup and I had the chip burned by GMTuners.com.
Anybody got any ideas?
Thanks.
Old Oct 9, 2005 | 11:03 AM
Vader's Avatar
Perhaps the chip burner disabled some of the error codes. Those can usually be turned off and on in the programming.
What year/type ECM did you use for the TPI?
Old Oct 10, 2005 | 10:19 AM
MiikeS's Avatar
It's off an '87 T/A so it's a '165 ECM. He should have disabled the EGR but any idea why I would be getting a code 42 from a scan but not from the SES light?
Thanks,
M.
Old Oct 10, 2005 | 08:52 PM
Vader's Avatar
The '42' may have been disabled as well as the '32'. The conditions that set it would still exist and be diagnosed, but would not write a '1' to the output table so the SES would light. Programming can get a little strange in those areas.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
